16 years agoRunning multiple images from EPCS (Factory & User)
Hi, I am aware that there have been many topics on subjects similar to these. I have read many of them and tried to make use of the suggestions and advice offered there but am still having a f...
16 years agoAndy, it would really helpful if you can organize the schematic of the board. Then you are able to determine on which MSEL pins you can get access. For example by removing some pullups or changing to pulldowns. May be you must scratch some PCB tracks or sold a new wire from the jumper to GND or VCC ...
For example, if the bord supports the AS (standard, 20MHz) then the MSEL[3..0] are 1101. If you can toggle MSEL0 and MSEL1 then you have the remote mode (1110). Jens
