9 years agoRunning a CYCLONE above its rated temperature
Hi, If I am running a T144 part which is rated for around 80 degrees C what would one expect to happen up to around 120 degrees Celsius? This will be the ambient temperature the device is run...
9 years agoThe T144 & E144 only refer to the package. You need to consider the temperature grade of the part - commercial, industrial or extended - the 'C', 'I' or 'E' suffix in the part number.
The 80 degrees you refer to is the maximum junction temperature, not the ambient at which you can operate it. I wouldn't expect any device to operate, for long, at 120 degC. Cheers, Alex
