run hello world in custom rootFS for agilex"
Looking for HPS Linus steps to add C Hello world and adding binaries/precompiled utilities to Linux rfs.
- EBERLAZARE_I_Intel
Please try to use the previous workaround provided, also I see that you have a case filed in IPS we will have our expertise to support you there.
I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Did the previous workaround work for you?
- MK_086
Thanks for checking.
We were facing several run time issues as shared before in multiple setups and halted our progress.
Any inputs on this please?
Thanks - EBERLAZARE_I_Intel
Any latest update for your testing?
Hi Kumar,
Can you check my previous comments?:
https://www.simplified.guide/linux/automatically-run-program-on-startup
You can refer this to auto start an application, it can be in any code e.g C, python.
Yeah, I can check that as well, it should be in the config of the kernel somewhere.
Also, regarding the connection error, it seems to be your VPN, can you try a different machine? Or you may need to set up proxy to bypass it.
- MK_086
While following these commands, we are facing problem to download the files from git as,
ubuntu@Precision-3650:~$ git clone -b langdale git://git.yoctoproject.org/poky.git Cloning into 'poky'... fatal: unable to connect to git.yoctoproject.org: git.yoctoproject.org[0: 52.88.119.210]: errno=Connection timed out git.yoctoproject.org[1: 44.232.17.94]: errno=Connection timed out git.yoctoproject.org[2: 54.214.149.138]: errno=Connection timed out
Can you help us to get through this?
Also, have a question that we are looking for help to autorun a Linux application from rootFS on Linux power on. Can you share us these steps as well please?
Do you have any update for this week?
Did you manage to bitbake yet? I did the previous and it did worked for me.
