14 years agoRS232 ip core qsys
I want to use rs232 ip core in qsys without nios2, is it possible ? I made it with vhdl code but now i want to use qsys and use ipcores. Thanks.
14 years agoThis is a very interesting question, I am considering doing the same thing. I did some searching. I think that you need to make the VHDL module compliant with the Avalon bus. Then you can use Qsys -> add new and configure your module. I have several vhdl modules that I would like to tie together with Qsys, so that I could use the System Console . . . hence the same motivation. Best, James
