17 years agoRS232 convert Lower case to Upper case
Really new to VHDL. I'm supposed to edit a code to convert lower case to upper case with a UART model.. can someone assist me. code is below.. library IEEE; use IEEE.std_logic_1164.all; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity MP0_top is port ( sysclk : in std_logic; -- RAD system clock RESET_low : in std_logic; -- Active low FPGA_SERIAL1_TX : out std_logic; FPGA_SERIAL1_RX : in std_logic ); end MP0_top; architecture rtl of MP0_top is ---------------------------------------------- -- Component declarations -- ---------------------------------------------- component mmu_uart_top port ( Clk : in std_logic; -- main clock Reset_n : in std_logic; -- main reset(phjones made active high) TXD : out std_logic; -- RS232 TX data RXD : in std_logic; -- RS232 RX data ck_div : in std_logic_vector(15 downto 0); -- clock divider value -- used to get the baud rate -- baud_rate = F(clk) / (ck_div * 3) -- bus interface CE_N : in std_logic; -- chip enable WR_N : in std_logic; -- write enable RD_N : in std_logic; -- read enable A0 : in std_logic; -- 0 - Rx/TX data reg; 1 - status reg D_IN : in std_logic_vector(7 downto 0); D_OUT : out std_logic_vector(7 downto 0); -- interrupt signals- same signals as the status register bits RX_full : out std_logic; TX_busy_n : out std_logic ); end component; ---------------------------------------------- -- Signal declarations -- ---------------------------------------------- signal reset : std_logic; -- Reset active high signal WR_N : std_logic; -- Active low write enable signal RD_N : std_logic; -- Active low read enable signal TXD_temp : std_logic; -- Allow output of TXD to test pin signal my_pulse : std_logic; -- Make sure load pulsed for 1 clk signal D_IN : std_logic_vector(7 downto 0); -- Data to Transmit signal D_OUT : std_logic_vector(7 downto 0); -- Data Recieved signal RX_full : std_logic; -- Byte of Data to Ready to read signal TX_busy_n : std_logic; -- Active low indicate busy transmitting begin -- Simple echo process ------------------------------------------------------------ ------------------------------------------------------------ -- -- -- Process Name: Echo -- -- Description: Determine when an character arrives then -- -- transmit the character back to the sender -- -- -- ------------------------------------------------------------ ------------------------------------------------------------ Echo : process(sysclk) begin if (sysclk = '1' and sysclk'event) then -- Defaults RD_N <= '1'; WR_N <= '1'; my_pulse <= '0'; if(reset = '0') then -- Check if a byte has arrived if(RX_full = '1' and TX_busy_n = '1' and my_pulse = '0') then my_pulse <= '1'; RD_N <= '0'; -- clear read full flag end if; ---------------------------------- Only to modify this section...... if(RD_N = '0' and TX_busy_n = '1') then WR_N <= '0'; -- start transmission D_IN <= D_OUT; end if; ------------------------------------------ end if; end if; end process Echo; -- Combinational assignments FPGA_SERIAL1_TX <= TXD_temp; reset <= not RESET_low; -- Port map UART UART_1 : mmu_uart_top port map ( Clk => sysclk, -- main clock (33 MHz) Reset_n => reset, -- main reset(phjones made active high) TXD => TXD_temp, -- RS232 TX data RXD => FPGA_SERIAL1_RX, -- RS232 RX data ck_div => x"0478", -- clock divider value -- used to get the baud rate -- baud_rate = F(clk) / (ck_div * 3) -- bus interface CE_N => '0', -- chip enable WR_N => WR_N, -- write enable RD_N => RD_N, -- read enable A0 => '0', -- 0 - Rx/TX data reg; 1 - status reg D_IN => D_IN, -- Data to send off-chip D_OUT => D_OUT, -- Data recieved to the chip -- interrupt signals- same signals as the status register bits RX_full => RX_full, TX_busy_n => TX_busy_n ); end rtl;No RepliesBe the first to reply
