15 years agoROM initialization
Hi, I need to initialize a ROM. I will probably use the Cyclone EP1C6 device. My questions are: 1. Is there a dedicated memory\way of declaration for ROM\RAM or can I just define it in my code in ...
15 years agoHi Tricky,
I'm using VHDL. BTW I couldn't find the coding lines you mentioned - there is only chapter 7 in section III. Anyway, I understand that it's ok to simply define an array? If there are no advantages using the megawizard I suppose that I'll go for that solution. Thanks
