10 years agoROM Initialization, Max 10 device 10M02
Hello, I am trying to use a Max 10, 10M02 (2K LEs) device. My design has a ROM, with the Initialization data in a MIF file. However Analysis & Synthesis run fails with the message.. (I am ...
8 years agoHello, I wanted to use 10M02SC-M153 with an application requiring initialized ROM.
Also found that "Compact Devices" do not support memory initialisation for a ROM made from internal RAM-blocks. 10M02SA-M153 does not exist (analog+flash) that supports memory initialisation >> I would have to use bigger 10M04SA-M153 Alternatively, I plan to use on-chip user flash UFM of 10M02SC to implement initialized ROM. ufm = iniitialized with file.hex/.mif >> this compiles into bitstream .pof and will program the ROM in the ufm, right ? In my design I will have to use "on-chip-flash-ip" avalon-mm to read from ufm. So far (design busy) I don not see any warnings/errors that this scheme is not ok .....
