17 years agoRMII Mode Selection / Strapping CYCLONE III
Hi, I am working in ALTERA CYCLONE III . I have designed a module with the following NIOS II Processor + Custom Ethernet MAC working in RMII Mode + SSRAM. The Ethernet PHY used in this FPGA i...
12 years agoDear daixiwen:
thank you for your reply,and I have some problems to: I can't ping the board,and I used the signaltap to test the mdio and phy_RXD(you can get info from attachments),the signatap process always waiting for trigger,did I miss sth? here is the nios debug detail: Running... INFO : TSE MAC 0 found at address 0x00002000 INFO : PHY National DP83640 found at PHY address 0x01 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 1000, Duplex = Full Waiting for link...OK IP address: 219.245.66.185 IP netmask: 255.255.255.0 IP gateway: 219.245.66.254 UDP Dest IP address: 219.245.66.112 OK. waiting for your reply,thank you!
