15 years agoRipple for input power supply
What is the minimum input voltage Ripple required for the cyclone II FPGA voltage of 1.2V and 3.3V. The spec is not given in the datasheet.
15 years ago --- Quote Start --- The spec is not given in the datasheet. --- Quote End --- I think it's well defined. Simply assume, that the instantaneous voltage has to keep the specified operation conditions, about +/- 4% for VCCINT. In addition, for devices without voltage regulator for analog PLL supply, a lower high frequency ripple may be required for stable PLL operation. This applies e.g. for Cyclone II VCCA. Pay attention to the VCCA bypass and filter recommendations.
