11 years agoRGMII RX Clock on a non-clock pin (normal pin)
Hi there, I have some timing problems with my rgmii rx interface. Due to a design error the rx clock is not connect to an dedicated clock pin. This error results a high delay on clock path and ...
11 years ago --- Quote Start --- I thought about soldering a wire on a clock pin, but I haven't found one with a via on the ball, which isn't used... So we are reconsidering a redesign.. --- Quote End --- Keep in mind that since this hardware has one error, it may have others, so its important that you hack/chop/drill/cut as much as you can on this board to isolate all the issues. So, if you do have another clock pin that is already used, and can remove that clock source for the purpose of this test, then go ahead and make that change (after testing whatever that clock source is used for, of course!). Cheers, Dave
