17 years agoreusing part of the testbench in different testbench
Dear All,
could someone give me a hint on a correct 'methodology'? Having a testbench to test single entity I'd like to use its parts in a testbench which tests one-hierarchy-level above entity. Example: have entity TLV5637 which uses 1us clock enable. The entity instantiates 'clock_divider', which provides me with this signal. In the testbench I have a process which verifies whether the 1us clock enable is really 1us. have upper entity DAC_TREATMENT, which instantiates TLV5637. The testbench for DAC treatment should test the 1us clock enable length as well. Is there any way how to re-use part of the testbench which was already created for TLV5637? Shall I put the part of the code into package and then use the package? What is the correct approach to make generic tests like those? thanks davidNo RepliesBe the first to reply
