16 years agorestricted fmax
My design with a Stratix2GX130 is timing-clean (no findings in TimeQuest' "report top failing paths"). The design is fully constrained, everything seems to be ok. But when I look at the list o...
16 years agoSince you dont' have any failing paths, I assume your restricted fMax are still high enough to meet your constrains.
Thus, no, it's not even a warning much less a serious one. The fMax report just provides some ballpark numbers on how fast each clock in your design could be. But it's really just a ball park number. (unrestricted fMax just takes into account the register-to-register delays The restricted fMax takes into account some more things, such as max I/O toggle rates. And neither takes into account signal that cross clock domains, for example.
