14 years agorestricted Fmax
I should have some IO speed, something like 500Mhz, not toggling but pulses as short as 2ns. The logic is a few counters that could also be resynchronized. Wit a Cyclone3 I reach something like 250Mh...
14 years agoWell i think the results you are getting are aligned to what it should be, although i have never worked with arria gx or cyclone so i cant comment on the 1Gb/s you are saying for the outputs but i really doubt that arria gx or cyclone can give such a baud rate.
Anyways i am also attaching a snap shot from arria2 gx manual. Might give you a better view of the max frequency operations. Nevertheless even if your lc count is only 50 even then i think the results are reasonable . If you provide some insight on the resource counts and your sdc some experts here might help you. GOOD LUCK
