17 years agoreset vector for NIOS II development kit
Hardware: Neek starter kit. I am trying to write some simple code for the NIOS II processor and I ran into some problems after building my SOPC system up. I am not not sure what is causing the...
17 years agoWhen you are debugging code, you should put your application in RAM, either DDR or onchip. You can set the reset vector, exception vectors and the application in the same area. Check also in the IDE that you put your application in the same memory (system library settings).
