10 years agoReset for PLL
I am working on a project involving Arria V FPGA. I need to have a PLL for generating clocks for my internal FPGA logic. I am confused about the reset signal of PLL. I have no external H/W reset...
10 years agoHaving just checked (I assumed the same as Cris) it seems the reset input port is 'required' for the Altera PLL suitable for Arria V - see the user guide (https://www.altera.com/en_us/pdfs/literature/ug/altera_pll.pdf). A quick play with Quartus confirms this.
POR pin? There isn't one - only an internal POR circuit for the device. I don't think there's any access to it. So, if tying reset to '0' isn't sufficient and you must generate a reset, I suggest you consider a counter that generates a reset at power up. And, if the PLL ever looses lock you can consider resetting the counter to regenerate the reset. Cheers, Alex
