12 years agoReporting path delays from quartus flow into timequest report
Hi, I'm struggeling with the tcl syntax of quartus. I learned just today that every tool has it's own packages. I'm using Quartus 13 I want to run quartus, and after quartus has comp...
12 years agoIt can't be sourced by the .qsf file, as it's not a setting. Follow the instructions above to add it to Assignments -> Settings -> TimeQuest. What you have will then show up in the TimeQuest compilation report, or you can add a -file field to the report_timing to put the report into a text report too.
