12 years agoReporting path delays from quartus flow into timequest report
Hi, I'm struggeling with the tcl syntax of quartus. I learned just today that every tool has it's own packages. I'm using Quartus 13 I want to run quartus, and after quartus has comp...
12 years agoCould you clarify what you did? (I do what I suggested quite a bit, so it should work).
