12 years agoReporting path delays from quartus flow into timequest report
Hi, I'm struggeling with the tcl syntax of quartus. I learned just today that every tool has it's own packages. I'm using Quartus 13 I want to run quartus, and after quartus has comp...
12 years ago --- Quote Start --- As a side note - TimeQuest outputs every command you set up in the TCL command prompt - so if you run something in the GUI you want to script up, you can just copy/paste it into your TCL file. --- Quote End --- That's what I did, but then quartus complains that the project settings are not correct. TimeQuest tcl from the gui uses a different packages then quartus_sta and quartus_fit. So the syntax is different?!?! between the two tooling.
