16 years agoRemove Nios referenced files from project no longer using Nios
Hi. I am facing the following problem. I recently remove the Nios from a design, and somehow the project still try to references some files, I have tried to search in the .qsf file but there is ...
16 years agoAre you sure you had removed the file paths from SETTINGS/FILES? That path is still included even if you have deleted the file.
