16 years agoRemove Nios referenced files from project no longer using Nios
Hi. I am facing the following problem. I recently remove the Nios from a design, and somehow the project still try to references some files, I have tried to search in the .qsf file but there is ...
16 years agoI did not find the cache, however I dont have any error on compiling, it is just the warnings. What I did. I remove completely the folder and fetch it again from my repository (svn) which includes only the needed source files. and no automaticaly generated files.
then I solve the previous problem. Now I still have some other linkages, to some other entities no loger existing. See Below. I will try to do the same procedure again to se if this time it is solved. Any other ideas where are this "global assignments set?" I allready look in the qsf file and there are no "OPTIMIZE_POWER_DURING_SYNTHESIS NORMAL_COMPILATION" options there. Warning: Found invalid Fitter assignments. See the Ignored Assignments panel in the Fitter Compilation Report for more information. Warning: Ignored assignments for entity "altsyncram_3ua1" -- entity does not exist in design Warning: Assignment for entity set_global_assignment -name OPTIMIZE_POWER_DURING_SYNTHESIS NORMAL_COMPILATION -entity altsyncram_3ua1 -tag quartusii was ignored Warning: Ignored assignments for entity "altsyncram_94m1" -- entity does not exist in design Warning: Assignment for entity set_global_assignment -name OPTIMIZE_POWER_DURING_SYNTHESIS NORMAL_COMPILATION -entity altsyncram_94m1 -tag quartusii was ignored Warning: Ignored assignments for entity "altsyncram_a3m1" -- entity does not exist in design Warning: Assignment for entity set_global_assignment -name OPTIMIZE_POWER_DURING_SYNTHESIS NORMAL_COMPILATION -entity altsyncram_a3m1 -tag quartusii was ignored Warning: Ignored assignments for entity "altsyncram_aai1" -- entity does not exist in design Warning: Assignment for entity set_global_assignment -name OPTIMIZE_POWER_DURING_SYNTHESIS NORMAL_COMPILATION -entity altsyncram_aai1 -tag quartusii was ignored Warning: Ignored assignments for entity "altsyncram_e2m1" -- entity does not exist in design Thankyou!
