16 years agoremote upgradation of FPGA
Hi, i m new to this topic.what type of stuff should i read to know more about remote upgradation of FPGA? Could you plz explain how to upgrade SOF or POS file in Cyclone III FPGA remotely through ...
16 years agoI've got to say I got a kick out of the term "upgradation".
There are a few components to remote upgrade: 1 - Uploading your new image to the FPGA 2 - Programming the new image into your configuration flash 3 - Remotely triggering the reconfiguration. Now you indicate that for# 1 you want to use ethernet. To me this means a NIOS processor running a TCP/IP stack. Then you can use FTP or TFTP or your own mechansim for getting the image down to the FPGA. However, if you're not using a NIOS, you've got to write some custom HDL to handle the ethernet. For# 2, you have a few options. If you are using a NIOS, it's pretty easy to interface to the flash and program the new data in. If you are not using a NIOS, you can use the PFL or SFL (parallel or serial flash loader) megafunctions to program the flash. # 3, use the remote_update core as std_logic_vector indicated. Jake
