17 years agoRemote Update with NIOS and EPCS
Hello, Currenty I'm working on a Cyclone III to try Remote Update work. I've searched for a lot of information but couldn't find specifiek how to work. I'm trying to work with the altremote_up...
15 years agook, I was able to flash my epcs using a .jic file and usb blaster.
then I was able to send a file from the PC through uart to nios and have nios buffer it in sdram and then write the file to flash at address 0. this is working! :D the file type I used was a .rbf and did byte reversal on all bytes of the file. I can power cycle and boot from the newly updated image written to address 0 of the epcs!!! The next step is to move the file to another location in flash so that I can have 2 images and use the remote update circuit to do a reconfig to the app image from the factory image. The question is, what effect does setting "Device and Pin options" > "Configuration mode" > "REMOTE" have on the output .rbf file? why do I need to tell quartus that the build is for remote configuration? Should both the factory default and the application configuration files use this option? I am not sure why it is necessary if I have the remote update HW in my SOPC?
