Remote Update of Cyclone 10
In my application I would like to have an application configuration that is normally used on every power cycle and a golden default configuration that is used only when the application config fails to load. This is intended to allow the application config to be revised and reloaded by an external uC into the config Flash. Based on my understanding of the documentation I should be able to assign my golden config as the factory at page 0 and my application at page 1. Then change the address register to point to the application start address. This will result in the power cycle loading the application config unless that config gets corrupted and then the golden (factory) config would be loaded. All the remote update examples indicate the address register needs to be updated from the factory config, but is there a way to change this setting just the once from the Quartus software or similar? I need it to permanently point to the application address.
Thanks for your help.
- FakhrulA_altera
Hi Brad,
Thanks for your understanding. I agree with you that it would be great if DTA mode could be extended to all Intel FPGA devices, and I will definitely share this feedback internally.
I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you for your patience and participation in the community.
Fakhrul
- BCrowell
Fakhrul,
Thanks for getting the definitive answer on this question. It would be great if DTA mode could be extended to all Intel FPGA devices as it has the best fit for our applications. We can make do with the remote update as is though.
Brad
- FakhrulA_altera
Hi BCrowell,
After checking with the internal team, I wanted to inform you that C10 LP doesn't support DTA mode (Direct to Application). DTA is a new feature exclusive to A10 and C10 GX only. Even in the RSU user guide, the DTA mode is explained under the A10 and C10 GX chapters.
Additionally, for A10 and C10 GX, there is an option for the boot address. However, C10 LP does not have it.
Fakhrul
- BCrowell
I think this thread has strayed a bit from my original question. What I want to do is have the Cyclone power on and use the application config unless there is an error and then it would use the factory config as a default. But I don't know if this is possible and how I set the remote config address register in this case. The main question posed from my original post is:
"All the remote update examples indicate the address register needs to be updated from the factory config, but is there a way to change this setting just the once from the Quartus software or similar? I need it to permanently point to the application address."
Brad
- FakhrulA_altera
Hi BCrowell,
Could you share the message error ID or provide the screenshot of it perhaps?
Fakhrul
- BCrowell
Fakhrul,
Yes, that is the example I am trying to simulate. I reviewed the user manual already and downloaded the design files. When I put together the simulation for these files and extended it to read the data from the update core though I get the X's when the registers are read back.
Brad
- FakhrulA_altera
Hi BCrowell,
Regarding the address register, you may refer to this Cyclone 10 LP Remote System Upgrade Design Example User Guide. The mentioned design example can be found here: Intel® Cyclone® 10 LP FPGA – Remote System Update Design Example
Fakhrul
- BCrowell
I agree with FvM as it appears Direct to Application is not included for Cyclone 10 LP. In my Cyclone 10 LP project however I can select that option to have the device auto restart after an error. Not sure that it means it will do it though. Also, in direct to application mode how does the address register get set in the remote update IP core?
- FakhrulA_altera
Hi BCrowell,
Please ignore my earlier comment. I consulted with my senior, who is an expert in RSU, and it turns out you can load the application configuration directly and only resort to loading the factory configuration if error occurs. This is known as "Direct to Application" (DTA). For more detailed information about DTA, please refer to pages 6-7 in the Remote Update Intel® FPGA IP User Guide : https://cdrdv2.intel.com/v1/dl/getContent/794025?fileName=ug_altremote-683695-794025.pdf
Fakhrul
- FvM
I see "DTA" mode provided only for Arria 10/Cyclone 10 GX, not Cyclone 10LP.
- FakhrulA_altera
Hi BCrowell,
The factory configuration initializes the FPGA into a known state, ensuring that all essential components are set up correctly. This is crucial for the reliable and safe operation of the FPGA. It helps prevent undefined behavior that might occur if the FPGA were to start with no configuration or an arbitrary state.
Fakhrul
- BCrowell
Fakhrul,
Can you expand on the details of what the factory config does to put the device in a known state? I guess I am wondering what I need to do in my factory config to ensure this occurs correctly? Also I wonder why the application config can't do the necessary things to ensure this proper state? If one is not using remote update, then there is only the application config in essence, so what ensures the device gets to a good state in this case?
Thanks for your help,
Brad
- FvM
necessary initialization in factory image is only related to remote update core, e.g. start address of application image and watchdog settings.
I must confess that I never tried to operate Cyclone 10 remote update core in a different way than suggested by user manual. It is definitely presuming that initial boot and mode transitions go through factory mode. As far as I understand, the behaviour is defined in FPGA silicone. MAX10 is operating slightly different, allowing also direct boot into application mode.
