17 years agoRemote update EPCS file format?
I have a Cyclone III EP3C5 design that uses an EPCS16 device in AS mode for configuration. I have successfully implemented the ALTREMOTE_UPDATE function as well as a function to load a new applicati...
13 years ago --- Quote Start --- The bits need to be reversed in every byte in the RBF file before being programmed into the EPCS flash. Jake --- Quote End --- hi jake! i read out all the EPCS4 data and compare with those RBF file showing ,i found that the difference was not only reversed in every byte ,but also same address with different data! could you please teach me why ? BTW ,I used QII 11.1 WINXP
