17 years agoRemote update EPCS file format?
I have a Cyclone III EP3C5 design that uses an EPCS16 device in AS mode for configuration. I have successfully implemented the ALTREMOTE_UPDATE function as well as a function to load a new applicati...
17 years agoAnother way to do it is use the sof2flash utility which is part of NIOS II EDS. When you do it this way, the bits are already in the correct order so you can use the output of sof2flash directly.
