16 years agoRemote Update Cyclone III from EPCS with NIOSII!!
I have created a combined hardware and software image for both the factory design and the application image and programmed them to the EPCS. However when I reconfiguration in NIOSII at the applicatio...
16 years ago --- Quote Start --- Have you created a custom bootloader to allow you to boot the application image? The default bootloader will not do this. You can program the FPGA with the correct fpga image but the default EPCS bootloader will always look at the factory software image. Jake --- Quote End --- thanks Jak, I mean that the remote config can't load the application FPGA image, I make a second FPGA(.sof) image in the EPCS, (The LED will show it running).but it shows that the second FPGA(.sof) image failed to load.
