15 years agoRemote Update Controller - Problem
Hallo together, I'm using an Cyclone iv. What I want to do is to switch between a factory image and a user image in epcs64. So I thought I could simply use the Remote Update Controller. I ...
15 years agoAtleast with SOPC Builder the .hex file is copied every time you regenerate the system. So you have to copy your modified .hex after you have run SOPC Builder, but before you run synthesis. I guess but haven't verified that the same is true with Qsys.
/Johan
