15 years agoRemote Update Controller - Problem
Hallo together, I'm using an Cyclone iv. What I want to do is to switch between a factory image and a user image in epcs64. So I thought I could simply use the Remote Update Controller. I ...
15 years agoHallo together,
now I think I could modify the default boot copier. But the next problem followed quick. How can I insert my modifyed boot copier in the ram from the epcs controller? First I tried to change the *.hex file in the Qsys-Projekt directory. I overwrote it with the modifyed *.hex file. But it seems if the default boot copier is still used. Then I tried to modify the *.c sources of the boot copier, in the altera install directory. But no effect. So does somebodey know, how I can use my modifyed boot copier in epcs-controller (in the qsys system)? Thanks sim
