15 years agoRemote update block gives pof_error...
We have intermittent problems with loading images from EPCS64 flash into stratix III. We us the remote update flow with 'factory' and 'application' images, both compressed, living in EPCS64. ...
15 years agoweird - i replied before but i don't see my reply now.
We have a scripted flow: set_global_assignment -name STRATIXIII_UPDATE_MODE REMOTE set_global_assignment -name STRATIXIII_CONFIGURATION_SCHEME "ACTIVE SERIAL" set_global_assignment -name USE_CONFIGURATION_DEVICE ON set_global_assignment -name ON_CHIP_BITSTREAM_DECOMPRESSION ON set_global_assignment -name STRATIXII_CONFIGURATION_DEVICE EPCS64 It works normally and is well tested. But if/when we get another failing image, I would like to find out why. And to find out, I need to know what altera check when they declare a "POF_error" in their remote update block. If they are only reading a few bytes in the header, then which bytes is it? And how would that protect against partially loaded designs? I don't think they read the whole file - it all happens too quickly...
