FabianL
1 year agoRemote Update Arria 10: Bitstream validation
Hello, I just came across the Note in 1.3.1. Remote System Configuration Mode that the factory fallback mechanism won't work for Arria 10 FPGAs if the last 576 Bytes of the bitstream are corrupted....
NurAiman_M_Intel
1 year agoHi,
Apologize for he delay in response.
The last 576 bytes should be standard for all Arria 10 application image, this is considering the full image only.
Provided you know the end of RPD file,you can always check the and match the CRC of the 576 bytes, they should always the same for the RPD generated from different Arria 10 design.
Aiman
