15 years agoRemote system upgrade of CYCLONE III+EPCS
Hi all,
I have a cyclone III device and a serial configuration device(EPCS flash),i fell puzzle about few questions as follow: 1: In Remote system upgrade, cyclone III doesn't need altasmi_parallel IP? cyclone III has dedicated circurt to control EPCS? 2: i want to put two image in EPCS(factory and user),how to caculate the image size in order to assign START ADDRESS in EPCS? Please help. Thanks a lot in advance3 Replies
yes, the EPCS controller will work automatically when you add ALTREMOTE_UPDATE IP in a cyclone III device.
Yes, you do not need to pay atention to it. - Altera_Forum
Thanks for the reply.
"That IP will use the dedicated EPCS controller."does it means the dedicated EPCS controller will works automatic when we add ALTREMOTE_UPDATE IP in cyclone III? The dedicated EPCS controller is dedicated hard logic in cyclone III, we don't need pay attention to it, am i right? - Altera_Forum
1. It does need altasmi_parallel IP. That IP will use the dedicated EPCS controller.
2. Build a factory image, measure it's size and Make surre "application" START ADDRESS is bigger than that.
