Remote System Update over PCIe generic Linux drivers/SDK availability and download location
- 2 years ago
Currently, we only have the Remote System Upgrade (RSU) Design Example via PCIe for Arria 10.
The RSU in the Design Example is via PCIe. You can get to the driver source files in the driver folder after you restore the Design Example.
If you want to use other low speed interfaces like UART or I2C, you may refer to the Max 10 Remote System Update Design Example.
- AN741: Remote System Upgrade for MAX 10 FPGA Devices over UART with the Nios II Processor
- Intel® MAX® 10 FPGA – I2C Remote System Update Design Example
VenTing_Intel
Thanks for reaching out to us at the Intel Community Forum.
You may select your target device from the list in Flash Loader > Add Device after selecting Arria 10 as device family. You can use the configuration device that is compatible with EPCQ when following the Design Example.
VenTing_Intel
Thanks - my question is more related to the CPU host side in the remote update architecture -- specifically are there generic Linux driver source files available for download similar to the CvP and passive serial drivers that can be downloaded
