17 years agoRemote System Update dilemma
Hello, I have a problem how to apply the Remote System Update feature in my system. Generally, my requirements are following: - an FPGA (Cyclone III) should be configured depending on w...
17 years agoI looked through "AN 521: Cyclone III Active Parallel Remote System Upgrade Reference note" and the reference design. Here I can see that by clickin on the RECONFIGURE button on the Cyclone III Starter kit (nConfig pin of the FPGA) it is possible to reverts back to the factory image. But I cannot see from the design block diagram that specific design component read this pin. Is it the PFL of the Remote_Update function?
If I want to use Remote System Upgrade with Active Serial scheme, should I just substitude the Parralel Flash loader component by the serial flash loader, or I should change the User Control Logic block either? Thank you. U.
