17 years agoRemote System Update dilemma
Hello, I have a problem how to apply the Remote System Update feature in my system. Generally, my requirements are following: - an FPGA (Cyclone III) should be configured depending on w...
17 years agoHi Guys,
thank you very much for your replies. Yes, uController is used to write some registers in the FPGA via SPI. I know it is better to use Nios II and get rid form a micro, but the problem that this is the first FPGA project in our company, and we cannot migrate right away. Hardik, If do not use the UController at all - then how to say the FPGA that the reconfiguration should be started? Reconfiguration should be started not only when the PCB is inserted to the rack, on the power up, but also if a master card is damaged and one of the slaves cards should become the master card.
