17 years agoRemote System Update dilemma
Hello, I have a problem how to apply the Remote System Update feature in my system. Generally, my requirements are following: - an FPGA (Cyclone III) should be configured depending on w...
17 years agoUilka b
Yes, Nios software. You can use ALTREMOTE_UPDATE in your design for your configuration. In your case you have to use active serial mode instead of active parallel mode. My suggestion, - Use two configuration for FPGA. One is default ( Master/Slave interface as you said ) and check after configuration. Switch to another configuration if required other wise keep FPGA configuration as it is. Regards, Hardik Sheth
