14 years agoRemote system Update / reboot from application firmware to application firmware
Hello everyone,
I'm using the remote update controller to reboot on a factory and an application firmware stored in my EPCS: 0x000000 Factory firmware (hard+soft) ¦ 0x200000 Application firmware(hard+soft) The remote update controller works well when the system runs with the factory FW and I decide to reboot on the application FW. My problem is when the system is running on the application FW. After having updated the Application FW in the EPCS, I'm trying to reboot my system on the updated version of the Application FW, but it reboots on the factory FW. I suspect that is not possible to reboot from application to application FW. And when I try to do this, the system reboot on the factory firmware (for security or something like this). Can anyone help me, please?2 Replies
When using Remote Configuration Mode (That is used with EPCS), you will always have to load Factory Image before you can reload Application Image.
See figure 1-2 in http://www.altera.com/literature/ug/ug_altremote.pdf - Altera_Forum
Look at page 14 of this document:
http://www.altera.com/literature/an/an603.pdf Hope this helps.
