12 years agoRemote configuration using Cyclone IV
I want to boot cyclone iv fpga(slave in attachment) in remote AS configuration. As mentioned in the handbook the bootflash should contain factory image and application image. What does the facto...
11 years agoHello!
I have the similar task. Please advise how to replace the content of EPCS4 by means of NIOSII? The AS configuration schematic on a custom board is as follows: http://www.alteraforum.com/forum/attachment.php?attachmentid=10117&stc=1 The original .jic file was programmed into EPCS4 in-factory via JTAG ( SFL ). To make in-field upgrade I plan to make NIOSII replace the original .jic file inside EPCS4 by a new one. After that replacement the next power-down/power-up cycle will load an upgraded version of .jic from EPCS4 into Cyclone IV. I know, that this approach has some drawbacks and risks, but I think it is the simplest to implement. Is there an Altera document, that describes how to make what I need? If not, then please advise how to make it.
