9 years agoReloading User Flash Memory without recompiling
I've got a soft-core CPU working onboard the Bemicro MAX 10 FPGA eval board. This is not NIOS II. The CPU boots code out of the User Flash Memory. After I reassemble and convert to .MIF, I need to re...
9 years agoFor NIOS II, if the program is in on-chip memory, you can use the option "update memory initialization file" in the Processing menu.
I think the same can be applied for any ram (if your processor exists in a RAM) that has an initialization file. After you click "update memory initialization file", you run the assembler only to generate the SOF.
