--- Quote Start ---
when checked the Modelsim reference manual,
i found the following commands for the question i posted
config list -strobeperiod {100 ns} -strobestart {0 ns} -usestrobe 1
add list -notrigger clk -window mylist a b c d
write list mylist.save;
I will check if this can solve my issue ,Thanks
--- Quote End ---
Dear all
With above commands i am able to create the list file
But problem came when trying to generate multiple list files
I am able to create two list files but the data will only be updated in only one list file
The window generated with
view list -new highlighted below
The commands i used are as follows :
set wind1 [view list -title wind1]
add list -notrigger -label a -window $wind1 simulationpath
set wind2 [
view list -new -title wind2]
add list -notrigger -label b -window $wind2 simulation path
run 50 us
write list -window $wind1 wind1.list
write list -window $wind2 wind2.list
Please let me know the reason behind why only one list file is updated
Thanks in advance for all your support
