7 years ago
Register vs Memory FPGA Cyclone V
Hi all,
I am still confusing between the registers (Array) and memory(Megafunction Altera Memory). What is the differences between them? Why are they different (I thought they are same)?
    A register is single bit storage. It's part of the ALMs (adaptive logic modules) that make up the fabric of the FPGA. Carry chains between adjacent ALMs allow for the easy construction of shift registers. Registers use standard register control signals: synchronous or asynchronous reset, clock enable, etc.
    Memory blocks are 2 dimensional storage arrays. They are addressable. They can be set up as single or dual port RAMs.
    You can certainly set up registers as a memory array. However, using the dedicated memory blocks is more resource efficient and provides more memory specific options that can give you better performance.
    I'd recommend reading the appropriate sections of the device handbook for the device you are targeting that discusses these resources to get more details.
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
    --- Quote Start ---
    --- Quote End ---
    How about's built memory? Is 2-Port RAM is built memory of Cyclone V? Between SDRAM and 2-Port RAM, which is better?
