15 years ago
Register initialization
Hello folks,
I have a shift register with no resets that I need to initialize. Will an initial value synthesize for Stratix III?
-Brad
    All registers power up on zero if you set "power up don't care" to false.
    In recent compilers they power up to initial value that you set when declaring signals. You will get warning if any register powers up high.
    You can power up to 'X' to give freedom to fitter.
    --- Quote Start ---
    --- Quote End ---
    Yes.
    In practice, all registers in the FPGA initialize to '0' and the software insert's NOT operations to make it look like it initialzied to '1'.
    You can now also use an initial statement in your source code to initialize the registers.
    initial is for simulation only , it will get ignored during synthesis and will not initialize. quartus 2 has an option in the Assignment editor called Power Up Level. you set it's value either 0 or 1. by default quartus initializes all registers to 0. link your register to that assignment, and set the value for it, to initialize a flip flop or a register to 1 when the system starts up.
    --- Quote Start ---
    --- Quote End ---
    This is untrue. Quartus now take initialisation values in code (aswell as async reset values) as the power up value. It has been doing this for several years!
    really? for example if i say
    module Trickytriestotrickme (slowestclock,WillMyLedLightUp)
    input slowestclock;
    output WillMyLedLightUp;
    reg WillMyLedLightUp;
    initial WillMyLedLightUp <= 1'b1;
    always @(posedge slowestclock)
    begin
    WillMyLedLightUp <= ~WillMyLedLightUp;
    end
    endmodule
    if i plug led to the altera's pin, will it start from "1" in the real world?
    Examples taken directly from the Altera HDL Coding Guidelins about register inital values.
    http://www.altera.co.uk/literature/hb/qts/qts_qii51007.pdf
    example 14–37. verilog register with high power-up value
    reg q = 1’b1; //q has a default value of ‘1’
    always @ (posedge clk)
    begin
      q <= d;
    end
    example 14–38. vhdl register with high power-up level
    SIGNAL q : STD_LOGIC := '1'; -- q has a default value of '1'
    PROCESS (clk, reset)
    BEGIN
      IF (rising_edge(clk)) THEN
        q <= d;
      END IF;
    END PROCESS;
    auch....! thats what happens when you study from books written in 1998 :) thank you so much.
