14 years ago
regarding verbosity_package.sv errors
in this thread, i see someone else has hit this same problem:
www altera com/forum/showpost.php?p=122019&postcount=10
i can't post that as a link since i only have 1 post...
the response to that question seems more focused on modelsim. however, i am seeing that exact error in quartus when i try to analyze and elaborate in preparation for simulation.
i do not see this problem if i run the simulation in ncsim, so it does seem to be a bug in quartus. i do have sytemVerilog checked everywhere in quartus.
i did a little hacking on this and it really does seem that quartus is confusing a void function for a task. if i edit verbosity_package.sv to make print() return a string and assign the return value of print to a dummy string, the file compiles just fine.
any ideas?
thanks
    --- Quote Start ---
    might take me a couple days at the rate things are going.
    --- Quote End ---
    Ok, I'll keep an eye out for it.
    Cheers,
    Dave
    sure, i can do that, i just have to go in and create a brand new one to make sure i don't have any proprietary IP in there. might take me a couple days at the rate things are going.
    --- Quote Start ---
    any ideas?
    --- Quote End ---
    Can you post a simple synthesizeable design showing the issue, and perhaps a testbench. I can run the code through Modelsim-SE to see if it complains. That would at least isolate the issue to being with Quartus. You could then file an SR and upload the same design.
    Cheers,
    Dave
