MartinMaa
2 years agoRegarding the 10M02SCM153, how should the unused pins, especially CLK and PLL, be handled?
Hello, I have a question regarding the unused CLK and PLL pins. Can they be left floating, or must they all be connected to GND? I reviewed the documentation again, and it suggests either groundi...
- 2 years ago
You can refer to each pin's requirement for unconnected ones in the pin connection guideline for MAX 10. If it mentions that you need to connect to VCCIO or GND, it means you can't leave it floating. There was no guaranteed behavior or effect on the device if you were not following the guidelines.
Refer link below for the MAX10 PCG:
Aqid
MartinMaa
2 years agoHello, if you are unable to assist me with verifying the SCHEMATIC, please let me know.
Additionally, could you please advise me on whether the unused CLK and PLL pins must be connected to GND?
Currently, my PCB LAYOUT is relatively fixed, so I have directly connected these pins to GND, that's easy.
Are there any other unused pins that require special treatment and cannot be left floating?
Thanks !
