14 years agoRegarding megafunction cycloneii_crcblock
I am trying to access the CycloneII_crc block using the megafunction (cycloneii_crcblock). I have appended my code with this message. The code compiles and synthesize and maps properly. However, when I try to run the timing simulations the output of the crc-block CRC_ERROR, REGOUT, always remain at undefined state. I tried several combinations of shiftnld and ldsrc. I suplied 50MHZ clock in the waveform, I ran the simulation for up to 50ms (which takes about 5mins to run)
Any help will be appreciated. Thank you in advance. ============my code================================= module light(a, f, y, x1, x2,CLOCK_50, e, z,); input a, x1, x2; input CLOCK_50; output f, y, z; output e; assign f=(x1&~x2)|(~x1&x2); assign y= ~z; cycloneii_crcblock XOR_research ( .clk(CLOCK_50), .shiftnld(a), .ldsrc(f), .crcerror(e), .regout(z) ); endmoduleNo RepliesBe the first to reply
