10 years agoReg: Max5 CPLD 5M160ZE64 clk/gpio pins ...
hi,
i had a question regarding the max5 5m160z cpld. i need to provide 4 or 5 clocks into my design. the max5 cpld databook says there are only 4 dedicated global clk pins (which can also be used as general purpose IO). since I need to give more clock inputs into my design compared to the no. of gclk pins available, i wanted to know if it's possible to use other general purpose IO pins to feed a clock into my design? my design is low speed (about 40MHz). also, i did try to compile my design in QuartusII and assigned the clocks in my design to a general purpose IO (instead of dedicated clock pins) and the tool did not complain. so i just wanted to know if this (feeding clock into cpld via GPIO) has been tried by someone on actual hardware and/of if there were any issues? please let me know ... thanks, z.2 Replies
hi,
thanks for your reply. i did look at the max5 cpld datasheet and the input clock rates for standard IOs is something like - IO standard family speed 3.3V LVTTL 5M160Z (C4, C5, I5) 304MHz since i am most interested in the 5M160ZE64A5 family, which is not mentioned in the datasheet, is there any information about this particular family's IOs and where could I find it? thanks, z. - Altera_Forum
Generally there are other Global signal routes so another clock should be without problem at these frequency..
