mstef1's avatar
mstef1
8 years ago
referring to my previous post, please let me add a strange condition
Chcking with oscilloscope the signal DATA0, after programming EPCS64 (with no errors), when I power-on the bord DATA0 stay to value between 1V.
I tryed to understand if this pin is set as general IO, but I ws not able to find where it is set (quartus 13).
could you please help me?
maurizio stefani
1 Reply
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    By default it will be tri-stated.
    You can find the option from
    Go to "Project navigator" -> right Click on the Device part-number->Select the "Device"->Click on "Devices and Pin Options" ->Under category go to "Dual Purpose-pins".
    Are you using development kit or custom board?
    What problem exactly are you facing during power-on?
    Check the pull up resistors.
    https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/hb/cfg/cyc_c51014.pdf
    Anand Raj Shankar
