16 years agoReduce Clock Setup and Clock Hold times
Hi there, I have a state machine witch makes some math operations. The question is how can I reduce the clock setup and hold times, so I can meet my timing requirements? Here is the code of the st...
16 years ago --- Quote Start --- Hi VT, did you write your arithmetic functions by yourself ? Kind regards GPK --- Quote End --- The math functions are asynchronous, generated by Altera's MegaWizard Plug-In. By the way what does the following warning mean:
Warning: Synthesized away the following LCELL buffer node(s):
Warning (14320): Synthesized away node "math_mult:math_mult_inst|lpm_mult:lpm_mult_component|mult_k3n:auto_generated|le10a"
Thanks, VT
