10 years agoRealize band filter and AGC function on low cost IC
Hello All, For mass production, we should choose low cost IC. And I have a question here, for low cost IC(eg. CPLD MAX II), is it possible to realize simple band filter function and auto gain c...
10 years ago --- Quote Start --- Hello Alex, Many thanks for your reply. The resolution is only 20 KHz. What I really want make sure is how to realize FIR in MAX II. Do you have any suggestion? Thanks a lot. Best, Mark --- Quote End --- Have you worked out how many taps you need. There are no dedicated mults in max II (as far as I know) so you will need to use adders to do the multiplication.
