10 years agoRealize band filter and AGC function on low cost IC
Hello All, For mass production, we should choose low cost IC. And I have a question here, for low cost IC(eg. CPLD MAX II), is it possible to realize simple band filter function and auto gain c...
10 years ago --- Quote Start --- How "simple"? What resolution are you after? Sample rate? You might be able to realise a particularly simple implementation of this in MAX II... Put a design together and run it through Quartus. It'll suggest a part. Having done that you can play around with different target parts, including MAX II. Cheers, Alex --- Quote End --- Hello Alex, Many thanks for your reply. The resolution is only 20 KHz. What I really want make sure is how to realize FIR in MAX II. Do you have any suggestion? Thanks a lot. Best, Mark
