9 years agoRead program from the CPLD Altera MAX7128S
Hello everyone, I am try to extract the program file from the Altera CPLD MAX7128S (type EPM7128STC100-6) but my experience is not enough. Try the read the information with the Altera Quartus II v.11...
9 years agoYour second screen shot shows a different problem - likely to be a faulty/damaged device or assembly.
No. You can't check whether the security bit is set. However, if you can't 'examine' it then it probably is set. Cheers, Alex
